Hello Everyone,
We have Meraki deployed in some for across all of our locations and slowly moving to full stack at all locations... I love everything I can do with Meraki but with that said I'm ready to take things to the next level … Enter API's.... I'm looking for advice where to start and get a crash course in there integration with Meraki and what all I can do.
Solved! Go to Solution.
Perhaps try the "Getting started with Meraki" learning modules.
https://developer.cisco.com/learning/modules/getting-started-with-meraki
If you want to level up, it's Python you are going to need to concentrate on.
The general resources for developers are located here:
https://developer.cisco.com/meraki/
If you want a quick feeling of success, scroll down to "How does the Python SDK work?" on that page and follow those steps.
Just to add to Philip's response, here's a simple self-paced lab that takes you through step by step and uses Postman to make some GET/PUT/POST commands and you'll get a really good feel for the Dashboard API in just an hour or two. https://developer.cisco.com/meraki/build/meraki-postman-collection-getting-started/
Yeah definitely postman and then python.
Have a look at this write-up I made not so long ago:
https://community.meraki.com/t5/Introduce-Yourself/Hullo/m-p/87641/highlight/true#M700
Best practice for me was just create a small organisation for yourself.. Add some devices to it..(just claim devices) . After 30 days , unclaim and add the device (or you can make a script which does that)
Think of what you want to achieve and just start programming in python which is a very easy language to master... Just like the good ole BASIC.
Postman is good for simple API commonds, but not suitable for making batch and check/loops etc. Once you are familiar in Python and Meraki API, you never use the postman program, only the Postman/Meraki API guide
https://documenter.getpostman.com/view/7928889/SVmsVg6K?version=latest#intro
Basic start with Meraki API is :
