Update Port Forwarding Rules Using Postman Runner
Brad_Walker
I have been attempting to update a list of port forwarding rules using Postman Runner. It runs through the iterations as expected, but when I check the configuration, it only shows the last rule from my .csv file.
The body code I am using is:
    "rules": [
        "lanIp""{{lanIp}}",
        "name""{{name}}",
        "allowedIps": ["{{allowedIps}}"],
        "publicPort""{{publicPort}}",
        "localPort""{{localPort}}",
        "uplink""{{uplink}}",
        "protocol""{{protocol}}"
What am I doing wrong?
TIA,
Brad Walker
Inderdeep
@Brad_Walker : Are you looking the below port forwarding using API calls
https://community.meraki.com/t5/Developers-APIs/Port-Forwarding-API-Uplink/m-p/94813
Regards/Inder
www.thenetworkdna.com
Some api calls do not add but replace the current rule. Like the fw rules you need to put all rules at once. I suppose this api call has the same behavior
Brad_Walker
Yes, I have tested it with the json and all rules added. I was kind of afraid of that. I am trying to automate some tasks for our Ops team and was hoping it would be easy to just import a csv, which is easier to update than json.
