That gets me to some more info I am needing, yet not the critical component.
In "Security & SD-WAN -> Configure -> SD-WAN & traffic shaping" section, there is "Local internet breakout" that I need to both set and validate. Right now, this is done by hand, and we have a few applications that can be hitting 40-50 different IPs.
What we are looking for, is a way to both update, as well as validate that the proper entries are there, that is NOT by hand, and NOT by template ( as templates do not work for our situation ).
We also have a script that updates our old VPN solution automatically, and if we can link that to a API, that would also help us with doing things by hand, and also reduce the mistakes and missing entries.
