- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Question on Switch Port Telemetry API
Hello Meraki Community,
I was testing out the port telemetry APIs, namely:
https://developer.cisco.com/meraki/api-v1/get-organization-switch-ports-statuses-by-switch/
https://developer.cisco.com/meraki/api-v1/get-organization-switch-ports-usage-history-by-device-by-i...
I realised that, despite my organization having around 40 switches (This information was obtained using https://developer.cisco.com/meraki/api-v1/get-organization-devices/), the APIs only showed port telemetry for 10 switches. I initially suspected that it was because some of the switches may not have had their ports active, or that the switch itself was offline, but I found that within the port telemetry response there were ports that were not enabled, and the devices were all online (https://developer.cisco.com/meraki/api-v1/get-organization-devices-availabilities/)
Surprisingly, when using the non-organisational level API:
https://developer.cisco.com/meraki/api-v1/get-device-switch-ports-statuses/
I was able to find port telemetry for switches that were NOT reflected on the org level API.
I believe my understanding is lacking somewhere, so I would appreciate some assistance with this discrepancy, thank you!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have found the problem:
It turns out that I did not realise pagination was applied to the API, thus reducing the number of records returned as the default was 10. Increasing the page limit using the query parameters got me the records i needed.
For anyone facing similar issues, this page explained how to overcome pagination to get all the records you need. https://developer.cisco.com/meraki/api-v1/pagination/#pagination
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes well figured out, pagination is important on these calls as there is #a lot# of data returned. Don't forget that if you don't want the data back on all switches there are query parameters/filters you can apply which cut the amount of data returned.
COO
Highlight - Service Observability Platform
www.highlight.net
