import json
import requests
import codecs
requests.packages.urllib3.disable_warnings()
base_url_v1 = 'https://api.meraki.com/api/v1'
apikey = "XXXXXXXXXX" #YOUR_API_KEY
orgid = "XXXXXXXXXXX" #YOUR_ORG_ID
headers = {
'x-cisco-meraki-api-key': format(str(apikey)),
'Content-Type': 'application/json'
def __returnhandler(statuscode, returntext):
if str(statuscode) == '200':
return returntext
else:
print('HTTP Status Code: {0}\n'.format(statuscode))
def getorgdevices():
results = []
geturl = '{0}/organizations/{1}/devices?model=MX'.format(str(base_url_v1), str(orgid))
dashboard = requests.get(geturl, headers=headers,verify=False)
if dashboard.status_code == 200:
raw = dashboard.json()
for i in raw:
results.append(i)
while 'next' in dashboard.links :
dashboard = requests.get(dashboard.links['next']['url'],headers=headers,verify=False)
for i in raw:
results.append(i)
return (results)
def getManagementInterface(serialnum):
geturl = '{0}/devices/{1}/managementInterface'.format(str(base_url_v1), str(serialnum))
result = __returnhandler(dashboard.status_code, dashboard.text)
return result
devices = getorgdevices()
f = codecs.open("DDNS.txt", "a","utf-8")
f.write("DeviceName,activeDdnsHostname,ddnsHostnameWan1,ddnsHostnameWan2\n")
f.close()
for device in devices:
ManagementInterface = json.loads(getManagementInterface(device['serial']))
ActiveDDNSHostname = ManagementInterface['ddnsHostnames']['activeDdnsHostname']
DDNSHostnameWan1 = ManagementInterface['ddnsHostnames']['ddnsHostnameWan1']
DDNSHostnameWan2 = ManagementInterface['ddnsHostnames']['ddnsHostnameWan2']
message = "{},{},{},{}\n".format(device['name'],ActiveDDNSHostname,DDNSHostnameWan1,DDNSHostnameWan2)
f.write(message)
f.close()
It is not the prettiest code ! but I was able to get that running in under 5 minutes and I have get going for the night.
I will create a textfile named DDNS.txt which you can then import into excel as a CSV with a ',' delimiter.
I tried it on 60 MX and it was giving me the right info. You will need to supply your API key and your ORG ID.
Have fun !
