- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Problem with changing MX uplink settings via the API
Folks,
has anybody got a work around for a problem I am having with updating the MX WAN ports
We have a customer who wants a script to disable WAN2 on all their MX 64s and it's a quite large estate
Although setting ["WAN2"]["enabled "] = False via updateDeviceApplianceUplinksSettings does indeed shut WAN2 the problem occurs about 10 seconds later when WAN1 seems to reset and leaves the device without WAN connectivity for 80 to 90 seconds
Although this is a 'just in case' script the customer wants I'm not sure that they would be happy with 1500+ 90 second disconnects across their estate.
I think the issue is because updateDeviceApplianceUplinksSettings requires values to be written to both WAN1 and WAN2
Even though WAN1 essentially has no change it still treats the update as a change and acts accordingly.
Has anybody found a way around this.
Initial thought were
Only write to WAN2 (API complains about empty fields not being permitted)
Use the regular ethernet port to disable the port BUT because the port is defined as a WAN port it doesn't appear as a regular ethernet port any more.
Meraki devs, can we have please address the WAN ports individually in the future please.
Thanks,
Rob...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hope this helps.
Can you try the "updateNetworkDeviceManagementInterfaceSettings" with WAN1 as "not configured" and WAN2 as "Disabled"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Unfortunately that has the same issue as updateDeviceApplianceUplinksSettings
I will probably dig into meraki.py at when I get time to see if both WAN ports have to be written with the PUT request or if I can add an extra function which allows better targeting of WAN updates
Thanks for taking the time though
BTW in the V1 method you can specify a single WAN port, but it still updates both
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, as this is a PUT request, it will perform a complete replacement of all the settings specified in the call, effectively deleting and reconfiguring all existing WAN settings associated with it. In contrast, a POST request merely appends new entries without modifying or removing any existing ones.
