Probing interface speed and Power mode
SysOP
Greetings. We are running a network with mostly MR44s and some APs randomly goes in to "Low Power Mode". Unfortunaltly there is no SNMP Trap, syslog or Webhook for this event and we would like to be notified somehow.
The interface (Wired0) sometimes also go into 100Mbit instead of 1 Gigabit. Often due to old/bad cables. Same problem here. It's hardly impossible to manually check hundreds of APs manually.
I tried to walk the MIB on the accesspoint. I have so far not found any interface speed or power mode status to poll. I also looked at APIs to extract this inforamtion.
I could check for changes at interface speed in the switch. Same for power that drops to 25 watt allocated instead of 30 watt.
2 Replies 2
Have you checked APIs for Event type?
https://developer.cisco.com/meraki/api-latest/#!get-network-events-event-types
or instead, you can monitor the switch ports where the APs are connected.
sungod
This call may have the info you need...
https://developer.cisco.com/meraki/api-v1/#!get-organization-wireless-devices-ethernet-statuses
It is org-wide, you could set up a script to run it every hour or some other period, and check for changes.
array[]
  • name:string
    The name of the AP
  • serial:string
    The serial number of the AP
  • -aggregation:object
    Aggregation details object
    • speed:integer
      Link Aggregation speed
    • enabled:boolean
      Link Aggregation enabled flag
  • -network:object
    Network details object
    • id:string
      The network ID the AP is associated to
  • -power:object
    Power details object
    • mode:string
      The PoE power mode for the AP. Can be 'full' or 'low'
    • -ac:object
      AC power details object
      • isConnected:boolean
        AC power connected
    • -poe:object
      PoE power details object
        PoE power connected
  • -ports:array[]
    List of port details
    • name:string
      Label of the port
    • -linkNegotiation:object
      Link negotiation details object for the port
      • speed:integer
        The speed of the port
      • duplex:string
        The duplex mode of the port. Can be 'full' or 'half'
    • -poe:object
      PoE details object for the port
      • standard:string
        The PoE Standard for the port. Can be '802.3at', '802.3af', '802.3bt', or null
