Network ID changed
boomi
Network ID changed
I have a network that was converted, I believe, from MX only to combined. Apparently this changes the network ID. Is this working as intended or a bug?
Why is the network ID not static? I noticed the old network ID still worked, and returned only the MX when I queried it for devices. Does a combined network actually have a 'combined' network ID then individual ones for each device type?
Seshu
Hello @boomi
Combined network has multiple payloads of config stored in it, each payload with its own networkID and the combined network on a whole with another networkID. So, the behavior is expected to change the networkID when converting an MX only network to a Combined one.
Please let me know if you have any questions.
Regards,
Seshu
Meraki Team
2 REPLIES 2
Seshu
Hello @boomi
Regards,
Seshu
Meraki Team
boomi
Understood, thanks!
