My Python script that uses the Meraki API is throwing a 502 Bad Gateway error today. It worked fine all week until today. Anyone know of anything going on?
Thanks!
Brian
Solved! Go to solution.
Hi ,
I think that Meraki is still having issues with their Mega Proxy. Can you try the exact same endpoint but replace api.meraki.com with your shard ? nXXX.meraki.com .
Thanks ,
Hi ,
Thanks ,
Hello RaphaelL,
Please excuse my noobness, but how would I find out what my shard is?
Thank you!
Brian
In dashboard look at the URL. nxxx.meraki.com. The xxx number is your shard.
rymiles, thank you for helping me find what my shard was.
Thank you, RaphaelL. Replacing api.meraki.com with my shard (nXXX.meraki.com) got my Python script to finally run successfully.
Maybe something to do with:
