You are right that for some reason, the PolicyObject Endpoint doesn't exist in the API Documentation on http://developer.cisco.com/meraki.
However, if you browse to the "old API documentation" you can actually find the endpoint there. When you're logged in to your Dashboard, click on Help -> API Docs.
![rbnielsen_0-1648838185358.png rbnielsen_0-1648838185358.png](https://community.meraki.com/t5/image/serverpage/image-id/22736iCC7B6EE85BEDF6CD/image-size/medium?v=v2&px=400)
There, browse down to Policy Objects. Previously they were known as Network Objects, but that API is deprecated. Now it's called PolicyObject - just like the endpoint that you have found yourself.
![rbnielsen_2-1648838497354.png rbnielsen_2-1648838497354.png](https://community.meraki.com/t5/image/serverpage/image-id/22738iF978F3E30FDB3EB8/image-size/medium?v=v2&px=400)
It's not optimal that Meraki has two different API Documentations and that they are not alligned. Hopfully that is something, Meraki will get fixed. Perhaps @MeredithW can help with poking the right people?
Anyhow, make sure to keep in mind to check both API Docs - the one at developer.cisco.com, and Meraki's own under the Help tab.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
