Import Cisco 2960 port configs to MS390
Capt_Caaaveman
I have a project upcoming to replace our cisco 2960 switches with MS390's.
I am looking to import the port configs from the 2960's to the 390's.
I cant seem to find a recent import discussion or script to look at.
I would like to do a switch at a time, as in target the SN/MAC of the 390 that I want to replicate the config to from a specific 2960 backup.
5 Replies 5
There is no ready-made tool for this, you need to use APIs.
https://developer.cisco.com/codeexchange/github/repo/fadysharobeem/Catalyst_to_Meraki_Migration_tool...
Capt_Caaaveman
Thank you.
I should have lead off with, that I am looking at a python API for this task.
I'm not sure if I want a bulk import like this.
I was looking more for an read csv, and update ports, per single switch kinda API.
You can find some options here:
https://developer.cisco.com/codeexchange/github/repo/meraki/automation-scripts/
You'll probably have to adapt this one.
migrate_cat3k: Proof of concept script to migrate switchport configuration from Catalyst 3750-X switches to Meraki MS switches. Uses action batches for better scalability.
Ryan_Miles
Meraki Employee All-Star
ecoen
#merakicat
