Device ClaimedAt Property
kbencze
I am looking for a way to get the date of when a device was claimed at. On the GUI I see this property displayed, but getting a response from the get device endpoint (https://developer.cisco.com/meraki/api/get-device/) does not help me, since the response does not have this information. Is it available on any other endpoint?
Thanks in advance,
Bence
If you had looked a little harder you would have found it.
https://developer.cisco.com/meraki/api/get-organization-inventory-devices/
You can check it over Organization -> Inventory
kbencze
Thank you for your answer,
I want to access this property through the API for integration purposes.
