Firmware Info via REST API
sherrick
Hello all,
Is there an API call that allows you to view the Firmware version of a device? I could not find this in data returned by Network and OrgID calls.
It looks like there's no calls for the Firmware update process as well. Having these methods would be extremely useful, as I work at an MSP. Are there any plans to support Firmware update via API calls, or even returned data with current Firmware version?
Thank you,
Steve
5 Replies 5
jdsilva
There are no API calls that I'm aware of 😞
Nash
I've got two major wishes for the API right now:
1. Pulling firmware versions.
2. Managing the client VPN when you're using Meraki Cloud credentials. 🙂
Maybe we'll get lucky soon.
AjitKumar
Hi Steve
I understand this shall not be possible.
You may also refer to the following communication
https://community.meraki.com/t5/Solutions-APIs/Using-API-to-return-template-bound-to-firmware-versio...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
sherrick
Shame to hear.
Thanks all for the replies
swifty
