Error "Invalid API key. A full (read/write) key is required"
mantis780
I cannot get the cloud monitoring for catalyst to connect to my dashboard. I get the error "Invalid API key. A full (read/write) key is required."
I cannot find a way in the dashboard to assign different permissions to an API key.
My user has access set to "full" under organization > administrators.
Oren
Was this a newly generated API key?
New API keys can take a few minutes to become active.
mantis780
Weird. I waited 15 minutes, I signed out of the dashboard, signed back in, clicked again on the green button in the "Cloud Monitoring for Catalyst" app and it worked this time, no error. I did not change the API key or any settings in the dashboard.
Problem solved.
Oren
mantis780
yes, it was band new, that was probably it. It would be helpful to have a small warning when creating and API key that reads "it can take up to X minutes before this API key becomes active, you may see the error "Invalid API key. A full (read/write) key is required." until the API key becomes fully active".
Keith_Li
realized i didn't enable following, after enabled i can generate API key
Enable access to the Cisco Meraki Dashboard API
