Device add script for sites already created in the Meraki dashboard?
Vbardy
Does anyone here in the forum have a simple device add script that will allow me to add devices, like aps, switches, cameras, to an existing Meraki site?  We use templates in our Meraki portal.
Please let me know if you do.
Thank you.
Rgds,
Vicky
Mloraditch
This is the API command to do this: https://developer.cisco.com/meraki/api-v1/claim-network-devices/
srajiwate
Hi Vicky,
Below is the tool made up of combination of python and api your need will be fulfill there you can claim devices in bulk in existing network or can create a new network also in organization below is tool easy to install and use
https://github.com/srajiwate/SR-Meraki-Mate
Check out the Meraki example automation scripts.  There might be something there as we..
https://github.com/meraki/automation-scripts
There is also the "Bulk Network Creation" tool.  It hasn't had any love for a long time.  It lets you create a CSV file of devices to add to networks.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Using_the_Bulk_Net...
