Data doesn't match Dashboard API Documentation
Just browsing
I'm trying to get data from the dashboard on devices.  The data I'm getting in Python doesn't match the Dashboard API Documentation or in Postman.  Any help would be greatly appreciated.
This is what I'm using and the output I'm getting.
url = "https://api.meraki.com/api/v0/organizations/#################/devices"
payload = {}
headers = {
'Accept': '*/*',
'X-Cisco-Meraki-API-Key': '###################################'
'address': '',
'configurationUpdatedAt': '2020-03-22T22:30:45Z',
'firmware': 'wired-15-10',
'lat': ,
'lng': ,
'mac': 'e0:cb:bc:24:a3:ef',
'model': 'MX65W',
'name': 'MX65W',
'networkId': 'L_64739244',
'notes': '',
'serial': '####-####-####',
'tags': '',
'url': '',
'wan1Ip': '8.8.8.8',
'wan2Ip': None
This is what I'm looking for
"name": "USMDHAG-2210-DSA02",
"serial": "XXXX-XXXX-XXXX",
"mac": "34:56:fe:ad:2d:f1",
"networkId": "L_64739",
"model": "MS120-8",
"address": "",
"lat": ,
"lng": ,
"notes": "SAFETY OFFICE",
"tags": "",
"lanIp": "10.132.10.20",
"configurationUpdatedAt": "2020-03-15T01:38:37Z",
"firmware": "switch-11-22",
"url": "https://n150.meraki.com/097"
Accepted Solutions
Re: Data doesn't match Dashboard API Documentation
You do have a switch  in the network ? Or only the mx65
3 REPLIES 3
If you share your code, I can take a look at it.
Edit out sensitive info of course.
Just browsing
Thanks for answer.  I realized that the MX doesn't have the same keys and switches do.  Thanks.
