Copy SSID with Python Library
KarstenI
Hi all,
I want to read an SSID from one network and push it to another.
When reading it, I get an object/dict like the following:
{'authMode': '8021x-radius',
 'availabilityTags': [],
 'availableOnAllAps': True,
 'bandSelection': 'Dual band operation',
 'defaultVlanId': 999,
 'dot11r': {'adaptive': False, 'enabled': False},
 'dot11w': {'enabled': True, 'required': True},
 'enabled': True,
 'encryptionMode': 'wpa-eap',
 'ipAssignmentMode': 'Bridge mode',
 'splashPage': 'None',
 'ssidAdminAccessible': False,
 'useVlanTagging': True,
 'visible': True,
 'wpaEncryptionMode': 'WPA2 only'}
but to push it, the API wants all elements individually:
response = dashboard.wireless.updateNetworkWirelessSsid(
    network_id, number,
    name='My SSID',
    enabled=True,
    authMode='8021x-radius',
    enterpriseAdminAccess='access enabled',
    encryptionMode='wpa',
    psk='deadbeef',
    wpaEncryptionMode='WPA2 only',
This problem is more based on my miserable programming skills, but how do I pass this source dictionary to the API call?
DarrenOC
Sorry I can’t help but glad to see that I’m not the only one struggling when it comes to APIs and Python.  Just not something I do day in and day out.
KarstenI
Thanks for your mental support ... 😉
KarstenI
I only had to go to page 5 on my Google search ...
https://community.meraki.com/t5/Developers-APIs/Python-dictionary-to-list/m-p/119919
source_ssid.pop('number')
    dest_network_id, dest_ssid_number, **source_ssid
Unpacking the dictionary is the key. Okay, now to the subsequent errors ...
I'm not expert in python, but maybe it can help you.
https://github.com/rmceoin/meraki
