Cisco Meraki Dashboard API 403 and performance problems
BasvanH
For the last two weeks we are experiencing performance problems with the dashboard API. Thru-out the day we also get some 403's, even with an extend HTTP timeout of 180 seconds.
Unable to connect to https://dashboard.meraki.com/api/v0/networks/L_XXXXXXXXX/devices": 7 Failed to connect to dashboard.meraki.com port 443: Timed out
Is this a known issue being worked on?
Regards,
Bastiaan
Greenberet
I would suggest to use api.meraki.com and not dashboard.meraki.com
dashboard.meraki.com remains in a datacenter in new york (according to geoip lookup).
api.meraki.com is more balanced around the world.
Also there is a redirect in place here.
dashboard.meraki.com -> redirects to api.meraki.com -> redirects to nXXX.meraki.com (where xxx is the shard/server on which your devices will register)
Greenberet
BasvanH
Alright, didn't knew that. I've changed the URL and see how this performs. Thanks!
BasvanH
api.meraki.com is much more stable, no timeouts anymore. Thanks!
