Certificate error when running api call from power automate
Fabio_Castaneda
Hi, I am trying to build a flow in power automate to get some basic information from the Cisco Meraki cloud. I am able to run the  API call by using Postman, Python, PowerShell, however, whenever I try to run the same call from Power Automate desktop or cloud, I am getting the same error and It fails from the begininng. "
"Error de la solicitud HTTP con el código de estado \"TrustFailure\" y el mensaje de estado: \"The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.\"."
Details of the call:
Headers:
  "Content-Type""application/json",
  "Accept""application/json",
  "X-Cisco-Meraki-API-Key""xxxxxxxxxxxxxxxxxxxxxx"
Of course it works from the Meraki site as well by providing the appropriate parameters..
I believe it is something related with the TLS certificate .... please I need your help...
Best Regards,
FAbio Castañeda
1 Reply 1
rhbirkelund
The megaproxy is being deprecated (if not already is..!), so try to avoid using that.
If you set the base url to api.meraki.com, what happens?
