CISCO Meraki MS 120 - Qualys Vulnerability Scan
Holiver
Just browsing
Hello Team,
We have a customer that uses CISCO Meraki.
I would like to know if is it possible to perform a Vulnerability Scans using some type of service credential? Authenticated Scan?
KarstenI
Yes, but it will not be that useful like the scanning of PCs for example.
There is not much to scan for what a login is needed. But it could be HTTP for the status page and SNMP.
8 Replies 8
KarstenI
Holiver
Just browsing
I tried to perform the scan via SNMP but it did not authenticated.
Is there any configuration that I need to perform on Meraki to enable the Scan via SNMP?
KarstenI
It has to be enabled:
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/SNMP_Overview_and_C...
You need to enable it for the devices (Network-wide > Configure > General > Reporting), not for the Dashboard.
Holiver
Just browsing
Hi, KarstenI.
The firewall team activated the SNMP settings according procedure, but the vulnerability scan does not authenticate with the community credentials.
Do you know someone who already managed to perform an authenticated Qualys Scan on Meraki via SNMP?
The Qualys Vulnerability Scan is able to peform this Scan on Meraki?
Qualys support/have compatibility to perform this Scan according to Qualys Matrix Support?
Link bellow (Authentication Technologies Matrix):
 https://success.qualys.com/support/s/article/000006761
KarstenI
Sorry, no. I don't have this anywhere running. But you can start troubleshooting by trying to query the device with snmpwalk.
Inderdeep
Yes, as we are using Qualys for all Cisco and Meraki devices as well. Go ahead
Regards/Inder
www.thenetworkdna.com
Holiver
Just browsing
Do you have some process or recommendation related to how to perform a vulnerability Scan?
BlakeRichardson
My advice with vulnerability scans is if you don't know how to do these I would approach a company to do this. This information needs to be accurate because if it's not and the customer gets attacked and the cause was something that should have been in your report you could be liable.
