Adding and Updating Celular Firewall rules does not change srcPort or destPort.
Clifra-Jones
I am working with the V1 API function Update Network Appliance Firewall Cellular Firewall Rules.
It seems the source and destination ports do not get updated when calling this method.
This is my message body I am sending to the API method:
  "rules": [
      "comment": "This is a test 3",
      "policy": "allow",
      "protocol": "any",
      "srcPort": "8080",
      "srcCidr": "192.168.129.0/24",
      "destPort": "80",
      "destCidr": "192.168.128.0/24",
      "syslogEnabled": false
It seems I can update any other property but the srcPort and destPort. I have successfully updated the comment and subnets several times.
Check out my Meraki API PowerShell Module.
Powershell Gallary: https://www.powershellgallery.com/packages?q=Meraki-API-V1
Project Site: https://github.com/Clifra-Jones/Meraki-API-V1
Ryan_Miles
You're using this endpoint https://developer.cisco.com/meraki/api-v1/update-network-appliance-firewall-cellular-firewall-rules/... Just tested on my MX and it works fine for source and destination port changes.
Ryan / Meraki SE
If you found this post helpful, please give it kudos. If my answer solved your problem, click "Accept as Solution" so that others can benefit from it.
2 Replies 2
Ryan_Miles
Ryan / Meraki SE
That’s what I was wondering. I am using the dev sandbox. I can’t test this functionality on my production MXs. All the other methods I’ve tested so far seem to work.
Good to know it works. I can move on to test other methods.
