API to pull port IP addresses
tjh188
Across all 750 networks in our organization we are supposed to have our Meraki MR36 plugged into port 11 of the Meraki MX68.  The MR36 are statically set to 10.x.x.3. We want to verify that 10.x.x.3 is actually being advertised by port 11 on the MX.
We are thinking that the AP is plugged into the MS120 in some network and we need to Identify where they are plugged in so we can call them to have them plug it in port 11 on the MX.
Is this possible through an API?
Maybe this API will help you.
https://developer.cisco.com/meraki/api-latest/#!get-device-lldp-cdp
2 REPLIES 2
Exactly what I was looking for!  Thanks Alemabrahao.
