- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to add multiple users by using API
I tried to add some users as "Meraki Auth User" with this page;
https://developer.cisco.com/meraki/api-latest/#!create-network-meraki-auth-user
I got 200, OK, when did via this site, by Meraki Python Library, and Python request template.
But I can't add some users at the SAME time.
Could you tell me some clues?
payload = '''{
"accountType": "802.1X",
"email": "xxx@test.com",
"name": "Test Meraki",
"password": "secretsecret",
"emailPasswordToUser": false,
"isAdmin": false,
"authorizations": [
"ssidNumber": 0,
"expiresAt": "Never"
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Example of untested python script
from meraki import meraki
import json
# Set up the Meraki API key
MERAKI_API_KEY = 'your_api_key_here'
meraki_api = meraki.DashboardAPI(api_key=MERAKI_API_KEY)
# Set up the network ID for which you want to create Meraki Auth users
NETWORK_ID = 'your_network_id_here'
# Define the function to create Meraki Auth users
def create_meraki_auth_user(email, name, password):
# Set up the payload for the Meraki API call to create the Meraki Auth user
payload = {
'email': email,
'name': name,
'password': password
# Make the Meraki API call to create the Meraki Auth user
try:
response = meraki_api.networks.createNetworkMerakiAuthUser(NETWORK_ID, payload)
print(f"Created Meraki Auth user {email}")
except meraki.APIError as e:
print(f"Failed to create Meraki Auth user {email}: {e}")
# Read the user list file
with open('user_list.txt', 'r') as file:
user_list = file.readlines()
# Loop through the user list and create Meraki Auth users
for user in user_list:
email, name, password = user.strip().split(',')
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can only add one user at a time. You would need to create multiple requests.
I haven't tried it with the user endpoint, but you could try action batches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Should just be able to accomplish it with a simple loop through a list for each call/user.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
import json
payload = {
'email': email,
'name': name,
try:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would give @LearningIsFun even more kudos if I could for including a code concept snippit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you @LearningIsFun
I tried this with a little arrangement for my environment, but I got an error below;
"Failed to create Meraki Auth user meraki.testmeraki2@test.com: networks, createNetworkMerakiAuthUser - 400 Bad Request, {'errors': ["'email' must be a string"]}"
Thank you again for your kind replies.
Warm Regards.
import meraki
import json
MERAKI_API_KEY = 'My_API_Key'
NETWORK_ID = 'My_Network_ID'
authorizations = [{'ssidNumber': 0, 'expiresAt': 'Never'}]
def create_meraki_auth_user(email, name, accountType, password):
payload = {
'email': 'xxxx@test.com',
'name': 'test meraki1',
'accountType': '802.1x',
'password': 'passwordcisco'
try:
response = meraki_api.networks.createNetworkMerakiAuthUser(NETWORK_ID, [authorizations], payload)
email, name, accountType, password = user.strip().split(',')
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Not sure, but sounds like the email you are passing is not being sent as a string, Try double quotes around the email address perhaps?
'email' : "xxxx@test.com"
That or the way you added in authorizations isn't passing correctly.
The code sample you posted doesn't appear to match what was used to generate the error.
