I'm new to API, recently finished the Devnet Meraki Express course.
I have been searching for the Dashboard API for live uplink traffic.
My idea is to fetch the data every 5 mins and convert to a flow chart in xls or google sheet. (Similar to Cisco IOS SNMP poll with Solarwinds or other monitoring tool)
I can't find anything on API guide
https://developer.cisco.com/meraki/api/#/rest/getting-started
I did find API for latency and loss....
Can anyone point me to the right direction?
Solved! Go to solution.
Hey @RichardChen1,
Personally, I prefer this reference for API info: https://api.meraki.com/api_docs
But use whichever you prefer. Just providing options 🙂
As far as I'm aware there isn't an API endpoint to pull the live traffic data. I don't think you will be able to do what you are asking. Sorry.
Hey @RichardChen1,
Rather than using the API, you could leverage Netflow. Something that‘s designed for this kind of task. 😉
Sure: Netflow is being used on networking equipment to showtraffic going over it.
It's a combined architecture with three components:
The exporter is typically a switch, router, firewall or loadbalancer. Flow data consists (at least) of
So basically, you're leveraging information that's available directly within the network to see what's going on in your environment.
Thanks @CptnCrnch
Will try that on the Auvik environment.
In this case, my netflow has to be on the Meraki LAN, not on the internet right?
I‘d guess. In Meraki-land the only device capable of delivering Netflow is the MX. It acts as the exporter then. You‘d have to implement at least a collector too additionally. Don‘t know if Auvik provides you with that.
