API for MX live uplink traffic
RichardChen1
I'm new to API, recently finished the Devnet Meraki Express course.
I have been searching for the Dashboard API for live uplink traffic.
My idea is to fetch the data every 5 mins and convert to a flow chart in xls or google sheet. (Similar to Cisco IOS SNMP poll with Solarwinds or other monitoring tool)
I can't find anything on API guide
https://developer.cisco.com/meraki/api/#/rest/getting-started
I did find API for latency and loss....
Can anyone point me to the right direction?
jdsilva
Hey @RichardChen1,
Personally, I prefer this reference for API info: https://api.meraki.com/api_docs
But use whichever you prefer. Just providing options 🙂
As far as I'm aware there isn't an API endpoint to pull the live traffic data. I don't think you will be able to do what you are asking. Sorry.
6 REPLIES 6
jdsilva
Hey @RichardChen1,
CptnCrnch
Rather than using the API, you could leverage Netflow. Something that‘s designed for this kind of task. 😉
Hi @CptnCrnch ,
Could you please elaborate a bit more on netflow with live network traffic data?
Sure: Netflow is being used on networking equipment to showtraffic going over it.
It's a combined architecture with three components:
  • Flow exporter: aggregates packets into flows and exports flow records towards one or more flow collectors.
  • Flow collector: responsible for reception, storage and pre-processing of flow data received from a flow exporter.
  • Analysis application: analyzes received flow data in the context of intrusion detection or traffic profiling, for example.
The exporter is typically a switch, router, firewall or loadbalancer. Flow data consists (at least) of
  1. Ingress interface
  2. Source IP address
  3. Destination IP address
  4. IP protocol
  5. Source port for UDP or TCP, 0 for other protocols
  6. Destination port for UDP or TCP, type and code for ICMP, or 0 for other protocols
  7. IP Type of Service
So basically, you're leveraging information that's available directly within the network to see what's going on in your environment.
Thanks @CptnCrnch
Will try that on the Auvik environment.
In this case, my netflow has to be on the Meraki LAN, not on the internet right?
I‘d guess. In Meraki-land the only device capable of delivering Netflow is the MX. It acts as the exporter then. You‘d have to implement at least a collector too additionally. Don‘t know if Auvik provides you with that.
