We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Is there an API call to enable Client-Data Privacy Settings under Network Configuration > General > Client Privacy? I can't seem to find it.
Kind regards,
Deny
Solved! Go to solution.
It doesn't appear to be part of the getNetworkSettings schema (https://developer.cisco.com/meraki/api-v1/get-network-settings/) so this would be a feature request for now.
