Hello everyone,
I have added VLAN's and Meraki cameras to 5 locations without any issues, the last location however is giving me nightmares. settings are all locations are same, different subnet for each location.
create VLAN for cameras VLAN 20 (Location-Camera)
create Static route for VLAN>Gateway
enable DHCP on VLAN
enable port for access with proper VLAN for camera (VLAN 20)
and cameras start working after firmware updates, 5 minutes top.
last location is giving me error when i try to add static route for VLAN>Gateway as below
i guess i am having overlapping ip, i have changed subnet IP for my VLAN to many IP"s that is not being used anywhere in my network. i verified that with all my records and global routing table, still not getting any results. the worse part is, my cameras not taking the ip from VLAN, so clearly there is an issue with DHCP server somewhere.
can anyone help me with this issue? i need help desperately. i am posting all the screen shots of the dashboard for the VLAN and switch settings if that helps.
