Search instead for
copy GROUP POLICIES to another network
is there any possibility to copy GROUP POLICIES from one network to another? The configuration templates do not offer this and using the API it's only possible to list (and create) device-specific policies.
We have a bunch of group policies, that I want to apply to other, already existing networks.
Thanks in advance,
Matthias Klein, KAEMI GmbH Berlin
Accepted Solutions
Re: copy GROUP POLICIES to another network
Thank you. This is a possibility and have a look at: https://community.meraki.com/t5/Solutions-APIs/Dashboard-API-copy-GROUP-POLICIES-to-another-network/...
Cheers,
Matthias
If you copy a network it should copy the Group Policies.
On a side note, what do you mean by "The configuration templates do not offer this"? I have some group policies in some of the templates I manage so each network bound to the template can use those policies.
Nope. Not possible Smiley Sad
If you have a lot of group policies I would consider copying an existing network to a new one, and then move the devices across from the old network to the new network.
Cheers,
Matthias
Hi @mklein,
That's no different than @MacuserJim's suggestion, just using the API instead of the dashboard. It's simple network cloning.
