Dashboard Sandbox API: This combined network does not contain a Systems Manager network
Fridal
I am trying to get a feel for how to work with the Dashboard API. I have been through a few tutorials and  read through the API Docs. I am testing the API using the DevNet Meraki Sandbox and Postman. Most of the API calls works as expected, but when I try to list the SM devices I get the following error: This combined network does not contain a Systems Manager network
Which probably makes sense since this is the Sandboxed version. Is there perhaps another way to use and test this?
Regards,
Bjørn
jdsilva
Do you have your own SM network? Test against that. If you don't then I think you're going to be out of luck unless you can find someone to let you hit theirs.
2 Replies 2
jdsilva
Thanks, I thought that might be the case. I will have to wait for my client to grant me access to their's Meraki organization.
