- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Why Firmware upgrade show equipement does not exist ??
Good morning I find the firmware management unusable
In fact, in the firmware to be updated, equipment is displayed on sites which do not contain this equipment!!
For example, it shows me MT sensor updates on sites that do not contain them... Management is not at all practical
- Labels:
Firmware upgrades
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Most likely it's because the network was created as a combined network, with all product types. If you had created the network at first as e.g. Security Appliance and afterwards added a switch or Wireless, it would have become a Combined Type but with only Security, Switch and/or Wireless product types.
To remove the MT and MV types you can select the network on the Organization Overview page. Tick the network, and click "Split". This will split the network into all product types that it contains. Then you can select the product types you are interested in, e.g. Security and Switch, and then click on "Combine". This will combine the selected networks into a Combined Network. The ones you are not interested, you can then simply delete.
If I recall, this does not have an impact to production, but it wouldn't hurt being in the side of caution, and do the first network split/combine in a service window to verify production impact (or lack thereof).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok thanks a lot
I will try these manipulations
I still find it poorly thought out...
My 51 networks are impacted... and on most of them I have never had MT or MR and even MS...
But it asks me to update the firmware on these sites...
Frankly a simple update filter would be enough
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Bartounet,
Linked below is the official firmware FAQ documentation referencing the inquiry and solutions provided by @rhbirkelund and @Ryan_Miles;
Managing Firmware Upgrades:
"Why does the Firmware upgrades page shows networks that do not have corresponding device types?"
The main benefit I find in keeping all of the product types updated in the combined network (even if a device is not currently within a network) is that if a device of that type is added in the future, it will automatically pull the latest stable firmware once it makes its initial contact to the Meraki Cloud.
Best,
Feli
