Vision portal SSO login
JKalmari
We have a working Azure SSO login to Meraki dashboard (made following the Meraki documentation) but for some reason SSO doesn't work on Vision Portal.
After giving credentials and passing MFA I get this error:
"The server encountered an SSO error. Please contact your network administrator for assistance. For reference, your login was at Nov 25 09:54:34 UTC from xx.xxx.xxx.xxx."
I tried making another app to the Azure just for Vision SSO login, but it didn't work either.
Any ideas welcome.
Ryan_Miles
Meraki Employee All-Star
Does dashboard show anything in the SAML history log for these failed login events? And if yes, what is the error?
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/SAML_Login_History...
Ryan_Miles
JKalmari
One learns something every day, like there is a SAML Login History. Can't understand how I haven't noticed that before. Thanks!
And yes, there's error: "Assertion validation error: Fingerprint mismatch"
So it is something with SHA1 fingerprint values.
EDIT:
I added SAML IdP thumbprint for Vision application and it works now. So simple and dumb that it almost hurts.
Thanks!
Ryan_Miles
Glad you got it resolved. That's exactly why I mentioned the log as it often gives a decently clear indication of what the mismatch is 👍
