I've had several instances of the Usage column on the Network wide->clients page reporting some wildly incorrect # (10-50 GB). On a network with relatively low usage, that stands out.
When you click this and look at the details of the usage (up and down) on the client detail page, the sum of the up+down usage is MUCH smaller (a 100 mb or so) - no where even in the ball park. I've always verified my time frame on both pages was the same.
I've seen this multiple times and created cases. In every instance, I've been told "engineering was looking into it" - but support was never able to offer a solution - nor has the issue been solved as far as I know.
Is anyone else seeing this behavior?
