Unable to Save Changes Dashboard
Net-working
Anyone seeing the following when trying change port settings on ms switches
There were errors in saving this configuration:
  • <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"> <head> <title>Page unavailable -- Cisco Meraki</title> <style type="text/css"> body { display: flex; flex-direction: column; justify-content: flex-start; align-items: center; margin: 0 2em; font-family: Helvetica, Arial, sans-serif; line-height: 1.45; color: #222325; /* same as $gray-10 in mkiColorVariables.json */ } .header__container, .content__container, .footer__container { max-width: 800px; width: 100%; } .header__container { padding: 2em 0; border-bottom: 1px solid #D7D7D9; /* same as $gray-80 in mkiColorVariables.json */ } .header__merakiLogo { height: 2.125em; } .header__merakiLogo--gray { fill: #898b8e; } .header__merakiLogo--green { fill: #67b346; } h1.content__title { font-size: 1.728em; /* from typographyBase.scss */ font-weight: 300; margin-bottom: 1em; } .content__container { margin-bottom: 1em; } .content__container a { color: #1D770B; /* same as $linkColor in variables.scss */ } .footer__container { padding: 1em 0; text-align: right; border-top: 1px solid #D7D7D9; /* same as $gray-80 in mkiColorVariables.json */ } .footer__text { font-size: 0.833em; color: #898A8C; /* same as $gray-50 in mkiColorVariables.json */ } </style> </head> <body> <div class="header__container"> <svg class="header__merakiLogo" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 130 25"><title>Cisco Meraki</title><rect class="header__merakiLogo--gray" x="13.29" y="16.46" width="2.06" height="8.17"/><path class="header__merakiLogo--gray" d="M32,18.8a3.64,3.64,0,0,0-1.73-.44,2.18,2.18,0,1,0,0,4.36A3.63,3.63,0,0,0,32,22.29v2.19a6.53,6.53,0,0,1-1.88.29,4.23,4.23,0,1,1,0-8.46,6.29,6.29,0,0,1,1.88.29Z"/><path class="header__merakiLogo--gray" d="M10.46,18.8a3.59,3.59,0,0,0-1.73-.44,2.18,2.18,0,1,0,0,4.36,3.59,3.59,0,0,0,1.73-.43v2.19a6.49,6.49,0,0,1-1.88.29,4.23,4.23,0,1,1,0-8.46,6.23,6.23,0,0,1,1.88.29Z"/><path class="header__merakiLogo--gray" d="M38.45,18.4a2.15,2.15,0,1,0,2.13,2.15,2.11,2.11,0,0,0-2.13-2.15m4.31,2.15a4.31,4.31,0,1,1-4.31-4.23,4.2,4.2,0,0,1,4.31,4.23"/><path class="header__merakiLogo--gray" d="M23.17,18.32a7.05,7.05,0,0,0-1.61-.25c-.83,0-1.27.27-1.27.67s.6.67.94.78l.57.18A2.46,2.46,0,0,1,23.74,22c0,2.05-1.81,2.74-3.38,2.74a12.56,12.56,0,0,1-2.22-.22V22.67a7.73,7.73,0,0,0,1.95.31c1,0,1.5-.3,1.5-.77s-.41-.65-.92-.81l-.44-.14c-1.15-.36-2.1-1-2.1-2.39,0-1.53,1.14-2.55,3-2.55a8.91,8.91,0,0,1,2,.26Z"/><path class="header__merakiLogo--gray" d="M2,7.68a1,1,0,0,0-2,0V9.83a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M7.66,4.87a1,1,0,0,0-2,0v5a1,1,0,0,0,2,0Z"/><path class="header__merakiLogo--gray" d="M13.28,1a1,1,0,0,0-2,0V11.87a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M18.9,4.87a1,1,0,0,0-2,0v5a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M24.52,7.68a1,1,0,0,0-2,0V9.83a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M30.14,4.87a1,1,0,0,0-2,0v5a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M35.77,1a1,1,0,1,0-2,0V11.87a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--gray" d="M41.39,4.87a1,1,0,0,0-2.06,0v5a1,1,0,0,0,2.06,0Z"/><path class="header__merakiLogo--gray" d="M47,7.68a1,1,0,0,0-2,0V9.83a1,1,0,1,0,2,0Z"/><path class="header__merakiLogo--green" d="M68.43,24.64,62.06,8.9V24.64H60.73V7.13h2l6.44,16,6.08-16h1.95V24.64H75.9V9l-6,15.61Z"/><path class="header__merakiLogo--green" d="M91.28,21.18A5.11,5.11,0,0,1,86,25c-3.43,0-6-2.36-6-6.69s2.5-6.69,5.76-6.69,5.71,2.19,5.71,7H81.36c.12,3.6,2.16,5.25,4.69,5.25a3.77,3.77,0,0,0,3.84-2.7Zm-9.9-3.65h8.75c-.17-3.24-2-4.84-4.35-4.84S81.63,14.37,81.38,17.54Z"/><path class="header__merakiLogo--green" d="M94.57,24.64V12h1.07l.19,2.43a3.67,3.67,0,0,1,3.55-2.8,4.51,4.51,0,0,1,1.31.2v1.29a4.93,4.93,0,0,0-1.39-.22c-1.85,0-3.43,1.8-3.43,4.84v6.91Z"/><path class="header__merakiLogo--green" d="M102.35,15.28c.19-2.16,2.12-3.65,4.91-3.65S112,13.21,112,15.79v8.85h-1.07l-.19-2.09A5,5,0,0,1,106.22,25c-2.46,0-4.23-1.33-4.23-3.57s1.31-3.48,4.86-4.06l3.79-.63v-1.1c0-1.82-1.29-2.94-3.45-2.94s-3.31,1-3.48,2.58Zm8.29,4.86V17.78l-3.4.58c-3,.51-3.89,1.46-3.89,3,0,1.7,1.31,2.55,3.21,2.55A4,4,0,0,0,110.64,20.14Z"/><path class="header__merakiLogo--green" d="M115.32,24.64V7.13h1.31v10L122.69,12h1.78L118,17.51l7.3,7.12h-1.77L116.63,18v6.69Z"/><path class="header__merakiLogo--green" d="M126.92,8.93V7.13h1.58v1.8ZM127,24.64V12h1.31V24.64Z"/></svg> </div> <div class="content__container"> <h1 class="content__title">Server error</h1> <p class="content__primaryText">The server encountered an error and could not complete your request. A message has been sent to our engineering and support teams to notify us of the problem, and we will fix it as soon as possible.</p> <p class="content__secondaryText">The Cisco Meraki Dashboard is temporarily unavailable, but rest assured your Meraki equipment is still running and network operation has not been interrupted. Learn more about Meraki's <a href="https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...">out-of-band control</a>.</p> </div> <div class="footer__container"> <span id="footer" class="footer__text">&copy; Cisco Systems, Inc.</span> </div> <script type="text/javascript" charset="utf-8"> //<![CDATA[ (function () { var year = new Date().getFullYear(); document.getElementById("footer").innerHTML = '&copy; ' + year + ' Cisco Systems, Inc.'; })() //]]> </script> </body> </html>
CarolineS
Community Manager
Community Manager
This is now being tracked on https://status.meraki.net Current status (2:15pm pacific on 3 Sept 2024) is:
Monitoring - Our engineering teams have deployed a fix which mitigates impact to customers. Customers should once again be able to successfully update switch port configurations via the Meraki Dashboard. We will continue to monitor systems to verify correct behavior.
Please subscribe at https://status.meraki.net for further updates.
txhomer
Also having this issue, nothing on the Meraki status page as of yet but I called support and it is a known issue they are working on.
Net-working
Ok thanks for that. I figured but did not see anything on the status page but the same issue looks to have happen Aug 27th which seem to be same issue but shows resolved.
CarolineS
Community Manager
Community Manager
