Template menu issue
adle
Template menu issue
Hello
starting from yesterday, the button to "Bind additional networks", "Unbind", "Rebind" in the setting page of a Template disappeared => we cannot bind an existing network to an existing template.
Now:
What it should look like:
10 Replies 10
bmehta
Meraki Alumni (Retired)
Hello @adle,
I would recommend you to open a case with Technical Support regarding this issue.
It is known issue and the internal team is working to fix it. By opening a case with Meraki Technical support you will be able to track the case for updates or resolution.
Aveanna
We are on day 2 with this issue. Support has been giving the same  response that the development team is looking into this. The responses are unacceptable.
MasonR
Having the same issue.
Aveanna
@MasonR  When did this start happening on your end? Are you getting the same responses from support ?
MasonR
Just noticed it this morning. I have been using the API for network adds for a few weeks now, so I am not entirely sure when the issue started. I noticed it while trying to rebind a network between two templates.
Aveanna
@MasonR  Thanks.
GreenMan
How does this manifest? - right now I can see the options you mention, in a sample Organization...
What is the latest you have heard from Meraki Support?
MasonR
Support told us that it was a known UI issue and that it would be resolved "soon". I did check just now and my functions have been restored. Support has not notified me of a change/fix.
Aveanna
It has been fixed. The scripted response and lack of follow up from Support was the most frustrating with this issue.
adle
yeah, it's fixed now indeed.
