TAGS NOTES
Willy_22
TAGS NOTES
I was trying to edit the notes on the dashboard but they are blocked, do you know what happened?
Willy_22
Thank you for contacting Cisco Meraki technical support.
This issue you are facing is a known problem to do with our end. Your notes are not deleted but are currently hidden and are being recovered as we speak. This is currently being investigated by our development team. As soon as I have an update for a workaround or fix I will notify you as soon as possible.
1 Reply 1
Willy_22
