Hello, I need to connect to a remote PC, it was fine until I enable this configuration:
"Client Routing / only send traffic to going to these destinations" and
"Dynamic Client Routing / Only send traffic going to these destinations"
This configuration has some CIDR and Hostname.
I wanna know if there is something I need to configure to allow me to connect remotely.
Solved! Go to solution.
What subnet is the PC on? Is any of these added in the config?
I add the subnet (172.16.6.0/24) and still doesn't work.
Take a look at this:
Client routing: This is used to specify full or split-tunnel rules pushed to the AnyConnect client device. You can send all traffic through VPN, all traffic except traffic going to specific destinations, or only send traffic going to specific destinations.
Dynamic Client routing: This is used to specify full or split-tunnel rules pushed to the AnyConnect client device by hostname. For more details see Dynamic Client routing
Local LAN access may be desired when Full tunneling is configured (Send all traffic through VPN), but users still require the ability to communicate with their local network. For example, a client that is allowed local LAN access while connected to the MX in full tunnel mode is able to print to a local printer at home, while other traffic flows through the tunnel.
To enable local LAN access, two things need to be done. Local LAN access will not work if both conditions are not satisfied.
1. Configure the MX: Select "Send all traffic except traffic going to these destinations" option on the Dashboard and configure a 0.0.0.0/32 route. This will cause the AnyConnect client to automatically exclude traffic destined for the user's local network from going over the tunnel.
Check the route details on Anyconnect:
Full doc: https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance
Hello again, sorry for the late response, I have finally been able to configure that. It still does not work, we have a split tunnel, and we cannot use (1)"Send all traffic except traffic going to these destinations" only (2)"Only send traffic going to these destinations"
Thanks.
