Summary report , usage %
gonzague
in the summary report, in the top device section, we see the usage and the usage %. Does anybody know against what value the % is calculated ?
HodyCrouch
You're seeing the usage of a single client against the usage of all clients that match the current filter criteria for the summary report.
Here's a sample from a smaller network where you can do the math by hand.  If I change the filter to show a single network or use a different date range, both the percentages and totals change as you would expect.
1 Reply 1
HodyCrouch
