Summary Report in Dashboard
SwitchIT
Hi everybody,
when i look on the summary report and filter for "Single Network" - "Appliance", i see the Firewall (MX67 in my case).
What does "Device Utilization" mean? Is this CPU? I want to know, if my Firewall reaches some limitations.
Where can i see CPU/Memory from the Firewall?
I have around 120 Clients per Day (50-80 concurrent Clients online).
Best regards
Bernhard Mauerhofer
2 Replies 2
RaphaelL
This should cover most of your questions : https://documentation.meraki.com/MX/Monitoring_and_Reporting/Device_Utilization
You can't see ANY other metrics about your device. You will have to reach out to the support to see those.
But there are no need to do that. If you are not reaching 85% of device utilization , don't bother checking RAM , CPU.
Currently, the device utilization value is calculated based upon the CPU utilization of the MX as well as its traffic load
If additional data is needed then please contact Meraki support who have access to more granular data to diagnose an over-utilized CPU.
