Split quantity of licenses
MauV
Just browsing
I have a question about licenses, we ordered 68 licenses for MR in one PO, but at the last minute the client decided to buy only 50. Is it possible to split the licenses and deliver only the 50 licenses?
Regards.
@SoCalRacer is right.  RMA the licences and order again.  Otherwise you are in for a nightmare.
SoCalRacer
My recommendation is RMA the licenses. In the long run it will be cleaner to have the order and dates match when they were deployed.
The other option is you could move the remaining to a different network/org. That may require support, but really isn't ideal.
MauV
Just browsing
