SSID Manager Role for Admins
Afonso
I need some help!
In my organization, on Administrators, in the new Admin operation it appears the option for a SSID Manager role, wich is exacly what I need, but when its time to choose a scope I choose the netwoks and then I cant choose specific ssid's, all of them get selected.
Thats one problem, the other and bigger one is that when I try to create a admin with that role, no matter if I choose 1, 5 or 300 networks it always give the same error:
How can I create new Admin that can only operate on specific ssid's on some networks?
Ryan_Miles
Meraki Employee All-Star
https://documentation.meraki.com/General_Administration/Service_Providers_-_SPs/Service_Provider_Das...
Note: This feature is only available to Service Providers and must be enabled by Meraki Support.
9 Replies 9
RWelch
Does the dashboard give you the ability to see STEP 2 (as seen above)?
Managing Dashboard Administrators and Permissions (Modernized View)
RWelch
Do you have organization wide or network wide admin permissions (yourself)?
Afonso
Yes I have full access in my organization, and I see all those steps but it does not allowed to choose specific SSIDs and when I do save after selecting the networks gives an error
RWelch
I would suggest opening a support ticket to have them take a further look, possibly support can gain more insight to the issue when they look at the error.
Afonso
Thank you! I will do that
Ryan_Miles
RWelch
@Ryan_Miles thanks for sharing and nice to know.  It would be nice if the link you shared Service Provider Dashboard Roles could be referenced on the page below (obviously not aimed or directed at or towards you):
Very helpful insight to what you shared.  Thank you.
Ryan_Miles
I submitted that feedback to the Doc team. Thanks @RWelch
Afonso
Thank you very much!!
