SNMP
JustinGA
SNMP
If you enable SNMP v1/v2, is there any kind of downtime with that?
For whatever reason it was never enabled before...
thank you!
5 REPLIES 5
Ryan_Miles
Nope
BlakeRichardson
@JustinGA  I am not sure what you are asking exactly.
I use SNMP to monitor devices within a boarder monitoring system we use and haven't found any issues with having it enabled. It's doesn't appear to have any performance impact on equipment.
I just want to make sure turning on options inside of Meraki doenst have any kind of downtime... i get like 1 hour a month for maintenance.
i didnt think it would, but i always double check and ask
@JustinGA ah gotcha, nope as Ryan mentioned there is no downtime with enabling it and good on you for checking.
Hope your maintenance goes well.
Haha.
With only 1 hour available, you must hit work up for a lab.  A separate network in Meraki with minimal gear that you can practice and test changes.  🙂
