SAML Jumpcloud Guide
meraki-newbie
Dear All, we want to using Jumpcloud as a SSO portal before login to meraki dashboard...
Is there any clear guide for Jumpcloud and Meraki side setup?
thanks
Here is it 😊
https://jumpcloud.com/support/integrate-with-cisco-meraki-dashboard
6 Replies 6
Here is it 😊
meraki-newbie
thank you
Ryan_Miles
Meraki Employee All-Star
I followed the guide @alemabrahao posted and got it working pretty easily.
@meraki-newbie If you run into any issues post back in this thread and we can assist you.
meraki-newbie
yep, it's seem pretty easy, but still lack of documentation, for jumpcloud step couldn't get as clearer than setting up on ADFS/Azure.. hopefully could have more details guides like this : https://www.miniorange.com/cisco-meraki-single-sign-on-(sso)
cheers
BlakeRichardson
@meraki-newbie For anything Jumpcloud related check out their support page, they have really good articles for all types of integration they support.
BlakeRichardson
This is a bit off topic but is there likely to be SSO supported for vision.meraki.com in the future?  Currently users have to access it via the dashboard and it would be a much nicer experience if users were able to login directly to the vision port via SSO.
