SAML Jumpcloud Guide
meraki-newbie
Dear All, we want to using Jumpcloud as a SSO portal before login to meraki dashboard...
Is there any clear guide for Jumpcloud and Meraki side setup?
thanks
Here is it 😊
https://jumpcloud.com/support/integrate-with-cisco-meraki-dashboard
6 Replies 6
Here is it 😊
thank you
Ryan_Miles
I followed the guide @alemabrahao posted and got it working pretty easily.
@meraki-newbie If you run into any issues post back in this thread and we can assist you.
yep, it's seem pretty easy, but still lack of documentation, for jumpcloud step couldn't get as clearer than setting up on ADFS/Azure.. hopefully could have more details guides like this : https://www.miniorange.com/cisco-meraki-single-sign-on-(sso)
cheers
BlakeRichardson
@meraki-newbie For anything Jumpcloud related check out their support page, they have really good articles for all types of integration they support.
BlakeRichardson
This is a bit off topic but is there likely to be SSO supported for vision.meraki.com in the future?  Currently users have to access it via the dashboard and it would be a much nicer experience if users were able to login directly to the vision port via SSO.
