Reset 2FA for my account
Roey1984
hello
I`m using Microsoft authenticator as my 2FA and intrested in moving my Cisco Meraki 2FA to be Google Authenticator.
What is the best practice to remove the 2FA and re-enroll?
Just to click on "Turn off two-factor authentication" and re enroll?
Ryan_Miles
That's it. When you re enable it will present a new QR code to scan.
Ryan
8 Replies 8
Ryan_Miles
Ryan
Roey1984
Thank you!
Just something to think about - Google Authenticator never used to be able to do a backup/restore (at least when I used it).  So if you loose your phone ... it's an extra bad day.
BlakeRichardson
Authy is a better option than Google Authenticator for exactly the reason @PhilipDAth  mentioned.
Although Authy has now withdrawn desktop support ...
Perumal
Hi  i am lost my old mobile and i am unable to login the 2fa authenticator DUO app with new mobile that cause i cant get the verification code .kindly help on this case how do i activate the duo app
Have your old number transferred to the new phone?
Perumal
Yes now i m using my old no only
