Reset 2FA for my account
Roey1984
hello
I`m using Microsoft authenticator as my 2FA and intrested in moving my Cisco Meraki 2FA to be Google Authenticator.
What is the best practice to remove the 2FA and re-enroll?
Just to click on "Turn off two-factor authentication" and re enroll?
Ryan_Miles
Meraki Employee All-Star
That's it. When you re enable it will present a new QR code to scan.
11 Replies 11
Ryan_Miles
Roey1984
Thank you!
Just something to think about - Google Authenticator never used to be able to do a backup/restore (at least when I used it).  So if you loose your phone ... it's an extra bad day.
BlakeRichardson
Authy is a better option than Google Authenticator for exactly the reason @PhilipDAth  mentioned.
Although Authy has now withdrawn desktop support ...
Perumal
Hi  i am lost my old mobile and i am unable to login the 2fa authenticator DUO app with new mobile that cause i cant get the verification code .kindly help on this case how do i activate the duo app
Have your old number transferred to the new phone?
Perumal
Yes now i m using my old no only
GerKeane
Hi , hope someone can help, we accidently erased a 2FA phone and realise that the Meraki account login was on this. How can we recover the account or who do we contact? , not a regular Meraki user.
Regards,
Ger.
spaladug
Hi @GerKeane . There is a process for Recovering Access to Accounts Protected by Two-Factor Authentication that Meraki Support can help with.
GerKeane
Thank you very much @spaladug , much appreciated.
