Remove Meraki Active Trial
kaoskuning
Anyone can give an advice, how do I remove Meraki Active Trial from The Dashboard, Because I Can't delete My Org if still have Active Trial.
Thank you,
Puji
6 Replies 6
DarrenOC
Remove the Trial eqpt from the Network it resides in.  You could also go a step further and delete the eqpt from that Org
kaoskuning
not for trial eqpt, but for trail license.
RWelch
Adding and Removing Devices from Dashboard Networks
GreenMan
I think you may need to contact your Cisco Meraki account team on this one.
Has the trial hardware been returned?
If so, I would reach out to support and ask them to cancel the trial for you.
kaoskuning
will try to ask support, thank you
