Organization wide alerting
peterwarwick
Hi All,
Is it possible to configure alerts for a whole organization instead of configuring network wide?
It would be very useful if this was possible.
Thanks,
Pete
No.  But you're right, it would be usefull.
6 REPLIES 6
That's pretty annoying.  looks like I'll have to go through all my networks individually and configure the same alerts.  Darn!
MarcP
yeah not the best solution at the moment.
Do "make a wish", surely others did already. But right now I don´t see the point for having this ?
Only thing you can do is to setup a template for future networks, where it is already configured.
BrechtSchamp
You could also use the API to loop through your networks and set it up:
https://developer.cisco.com/meraki/api/#/rest/api-endpoints/alert-settings/update-network-alert-sett...
I can't find the api to do that...does anyone know where that api is?
