Organization wide alerting
Hi All,
Is it possible to configure alerts for a whole organization instead of configuring network wide?
It would be very useful if this was possible.
Thanks,
Pete
Accepted Solutions
Re: Organization wide alerting
No.  But you're right, it would be usefull.
4 REPLIES 4
That's pretty annoying.  looks like I'll have to go through all my networks individually and configure the same alerts.  Darn!
yeah not the best solution at the moment.
Do "make a wish", surely others did already. But right now I don´t see the point for having this ?
Only thing you can do is to setup a template for future networks, where it is already configured.
You could also use the API to loop through your networks and set it up:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm#f9257cfe-3add-410a-9901-3e...
