One order Number two organization names 3 yr license
JamesMutie
I have moved the two organization to per device licensing and added a test device in each. When I check at all products licensed in license info, it shows the expiration date as Jun 22, 2021 which is 30 days from the date have added the devices. Does this mean, My 3 year license will self activate after these 30 days?
Accepted Solutions
Re: One order Number two organization names 3 yr license
Also, one order number can't cover two organisations as far as I am aware, you might need to talk to support if one device and licence should be in the second organisation.
6 REPLIES 6
@JamesMutie did you convert the organisation and then add the license by using the order number?  Or have you just added the device by serial number?
JamesMutie
@cmr I hacked it finally.
When I was adding the order number I forgot to add the license option as well.
JamesMutie
@cmr  With per device licensing , it is possible to have one order many organizations. All I did was, add the devices and their licenses to one organization , Then under license info>>devices select the device you wanna move and then under >>more actions>>select move to a different organization>>choose the org>>review and submit. Done!!!
Thanks a lot the heads uo
Thanks @JamesMutie , of course with device licensing it doesnt matter as they are all assignable! 🤦‍♂️
JamesMutie
Welcome @cmr . It is a good feature, you just need to have full access rights to the two orgs.
