Offline Meraki Backup
I have refreshed my offline Meraki backup script.
https://www.ifm.net.nz/cookbooks/meraki-backup.html
This backups a Meraki organisation to a local file on your computer.  The backup file is in fact another Python script that you simply run to restore the config.
Because the restore script is a Python script you can just edit it to restore whatever you want, or to restore it to a new place.  It also provides an easy way to see how a particular API can be called.
1 REPLY 1
Re: Offline Meraki Backup
Love your work, some good old kiwi ingenuity there! 😎
